WWenx
7 years agoALTFP_MATRIX_INV IP core output wrong result
I use the IP core ALTFP_MATRIX_INV of 4*4 matrix inversion, but the result of inversion output is wrong. The output of a full rank matrix (e.g. {1,2,0,0;3,4,0,0;0,0,0,0,1,0;0,0,0,0,1}) is an abnormal...
CheepinC_altera
7 years agoHi,
Sorry for the delay. As I understand it, you observe some issue with the ALTFP_MATRIX_INV IP in Modelsim simulation. To ensure we are on the same page, would you mind to further elaborate on the following:
- What is the device that you are using and Quartus version?
- Thanks for attaching screenshot. To facilitate further understanding, would you mind to further elaborate on the output result that you are expecting and also probably add some markers on the screenshot on the section that you observe issue. For example, with specific input, the expected result vs wrong result in the simulation.
Thank you very much for your help.
Chee Pin
WWenx
7 years ago
