SDe_J
7 years agoAltera Triple Speed Ethernet with DP83848 ethernet board on a Cyclone V GX starter kit
Hello Intel Forums, I have a Cyclone V GX starter kit (https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=167&No=830). This kit has no ethernet port, so I've added a DP83...
Nathan_R_Intel
Contributor
7 years agoHie,
The Triple Speed Ethernet does not support RMII. As you are aware it only support RGMII, MII and others. The converter card is not Intel's recommended method as we have not validated it in-house. Hence, this is out of specs use case. Hence, I cannot guarantee this will work. However, I will try to guide you by providing some guidelines on the next debug steps.
It seems you have done the first level due diligence by checking if the Physical connections and Phy clocks can be detected and it seems to be detected.
What I recommend next is; you could try to access each Phy device by writing the Phy address to the MDIO registers. Ensure the AVMM is accessing the MDIO registers correctly. Please refer to section 4.1.12 and subsequent sections of user guide:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf
Nathan
SDe_J
7 years agoHi Nathan,
Thanks for your advice, I'll look into this.
Just to be clear, I'm not using a physical coverter to convert the MII from the triple speed ethernet into RMII, I'm using a VHDL module. I only have one PHY attached, so I'm confused that the simple socket server thinks there's multiple.
-Sam
