9 years ago
altera_dma driver for PCIe
Hi everyone, i'm using an Arria V starter kit for PCIe application and i used the reference design posted in altera wiki. The application software reported success in one PC but not in other with different features. The driver code is installed in two with success but in one, user application reported timeout for read, write and simultaneous RW. Had anyone has the same problem? Have anyone some suggestion about what can i do to try solve this problem?
  • Hello All,
    1. I'm having the same issue. Has anyone found a solution for the "Couldn't open the device." error?.
  • HungLam's avatar
    HungLam
    It was so bad when Altera merged to Intel, so many reference links broken. And reference design was so weird, it has not been working as stated in Application Note.
  • 小孟000's avatar
    小孟000
    My c10gx develepoment kit has the same problem:
    when lspci : Non-VGA unclassified device: Altera Corporation Device e003 (rev 01)
    when ./run : Couldn't open the device
    my linux version is ubuntu 16.04, 64bit,
    Is this driver for linux-64 or 32?
    how can I make it ok? I refferd to app AN829,but it looks like not work.
    Best Regards!!​
  • BAPAYYAK's avatar
    BAPAYYAK
    I am using arria10 GX dev. kit. I couldn't find Fair LINUX DRIVER in search for "AVMM_DMA_On_Chip_Mem" as Alterawiki is not continuing is the result. Could you please provide a decent link to download drivers for the above. Thanks in advance.
