9 years agoaltera_dma driver for PCIe
Hi everyone, i'm using an Arria V starter kit for PCIe application and i used the reference design posted in altera wiki. The application software reported success in one PC but not in other with dif...
8 years agoHi, talking about reference design for Arria V, i solved the issue modifying PCIe memory address space from 32(default in reference design) to 64, maybe will work for you also. You just need call Qsys and there, click in avmmdma_pcie instance. In the configuration window you will see the memory address space parameter.
