9 years agoaltera_dma driver for PCIe
Hi everyone, i'm using an Arria V starter kit for PCIe application and i used the reference design posted in altera wiki. The application software reported success in one PC but not in other with dif...
8 years agoHave you checked if the FPGA has been programmed successfully and if the board has been enumerated properly in the PC? If using Linux, run the lsmod command and check if the driver is loaded. Have you checked if the device ID in the driver matches with the one in the board?
