BIdro
6 years agoALTDDIO IP Cyclone V GT
I’m using the ALTDDIO intellectual property but I have problems with it.
The ALTDDIO-Input works very well.
The ALTDDIO-Output does not work. I generate a clock, input signals (reset, data_...
- 5 years ago
I discovered that the ALTDDIO works but I can not monitor its output with Signal-tap.
Thank you for the support.
BR
Bryan
JonWay_altera
5 years agoHi, It could either be a Quartus version or a design issue.
You can try to use the 18.1 version
and
also you can try the example design from this link:
BIdro
5 years agoHi,
BR
Bryan
