NJOUB1
7 years agoALTASMI_PARALLEL in full synchro design. Can I use the same clock and edge (rising edge ) for clkin and the rest of the design?
I use a ALTASMI_PARALLEL and a ALTEREMOTE_UPDATE megafunctions in a cyclone III. All the design is full synchro and use a rising edge of a 12MHz clock. I want to know if it's possible to use the same...
Nooraini_Y_Intel
7 years agoHi NJOUB1,
The answer can be found from the other thread that you have posted:
You can use the same clock source as the clock input for both ALTASMI_PARALLEL and ALTEREMOTE_UPDATE megafunction. There is no restriction that you need to use different clock source to each IP/megafunction.
Nooraini
