K606
Contributor
1 year agoAgilex5: XVCR Toolkit
I am trying to use the XVCR Toolkit on the Atum A5 by following the user guide SPEC: In Section 3.7.2 the clock connections are defined: I am using PMA clocking, with a Phase Compensation FI...
Ash_R_Altera
1 year agoHi,
As I understand, you need to make the XCVR toolkit work. You've enabled options and made connections as per the following method:
3.12.2. Using JTAG to Avalon Master Bridge Intel FPGA IP
May I know how are you handling the reconfig_clk and reconfig_reset signals? I don't see them in the code snippet.
K606
Contributor
1 year agoHi,
I have connected them to the HPS system clock and the system reset.
