zener
5 months agoAgilex3/5 GTS Hard Ethernet IP 10G example design pin loc and io std wanted
Where can I find any public available dev kit design example for the Agilex3 or Agilex which can implement the GTS Eth HIP as generated by Quartus Pro v25.3 and successfully build a sof file? A set ...
paveetirrasrie_Altera
5 months agoHello Zener,
The example design does not include pin location or I/O standard assignments when “board = None” is selected. This is expected because the GTS Ethernet Hard IP relies on fixed transceiver resources, which must be mapped based on the target hardware.
To resolve this, use a dev kit example as reference.
Pavee
