Agilex 5 GTS PMA/FEC Direct Loopback
- 1 year ago
Thanks for your update.
Based on your description, it seems your datapath is structured as follows:
Oscillator → tx_parallel_data input → GTS PHY → rx_parallel_data output → DMA → HPS
To achieve this setup, you can enable the Parallel Loopback path (Path B). This configuration allows the parallel data fed into the TX interface to be directly routed to the RX interface, bypassing the serializer, deserializer, and CDR blocks.
This approach should help simplify your testing or validation process without involving the full high-speed serial path.
Let me know if you need further clarification or assistance.
Chee Pin
I believe that your initial question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Altera experts. Otherwise, the community users will continue to help you on this thread. Thank you very much.
