Manuel4
1 year agoAgilex 5 E-series 065A GTS PMA/FEC Direct PHY
We want to use an Agilex 5E device Group A to make a 4x25Gbps transceivers integrating RS-FEC. When I use Quartus Pro 24.3, the only transceiver PHY is the GTS PMA/FEC Direct PHY Intel FPGA IP, and ...
paveetirrasrie_Altera
1 year agoHi Manuel.
When you select the RX Simplex setting for the PMA mode parameter, the Number of PMA lanes selection is limited to 1.
May I know what your IP setting?
Pavee
- Manuel41 year ago
Here my settings. I need 4 lanes with RS-FEC enabled.
