OLevy1
7 years agoadding 2 high speed reed solomon decoders increased the 'Logic Utilization' in 20% (only 7% was expected based on other project where i also added the same 2 high speed reed solomon decoders).
based on the reports i have attached (5100 is before i added the decoders and 5101 is after), can someone tell me why the 'Logic Utilization' increased so much? thanks, Oren
CheepinC_altera
7 years agoHi,
Thanks for your update. For your information, after design compilation, you can check the resource utilization by the HS RS decoder instance at Fitter -> Resource Section -> Resource Utilization by Entity. You may then cross check the resource utilization between your two design to see if there is any anomaly.
Chee Pin
