OLevy1
7 years agoadding 2 high speed reed solomon decoders increased the 'Logic Utilization' in 20% (only 7% was expected based on other project where i also added the same 2 high speed reed solomon decoders).
based on the reports i have attached (5100 is before i added the decoders and 5101 is after), can someone tell me why the 'Logic Utilization' increased so much? thanks, Oren
CheepinC_altera
7 years agoHi,
As I go through the QSF files and perform a diff, for your information, I do not spot significant different which might lead to the resource utilization difference. The only different which might be related is the following:
5100.QAR
set_global_assignment -name FITTER_AGGRESSIVE_ROUTABILITY_OPTIMIZATION NEVER
5101.QAR
set_global_assignment -name OPTIMIZATION_MODE "AGGRESSIVE PERFORMANCE"
I am not sure how these would impact the utilization but for better comparison, generally it is recommended to use the same settings as much as possible.
Chee Pin
