OLevy1
7 years agoadding 2 high speed reed solomon decoders increased the 'Logic Utilization' in 20% (only 7% was expected based on other project where i also added the same 2 high speed reed solomon decoders).
based on the reports i have attached (5100 is before i added the decoders and 5101 is after), can someone tell me why the 'Logic Utilization' increased so much? thanks, Oren
OLevy1
7 years agothanks Chee,
indeed there is a difference in the XCVR channel because i reduce the triple speed Ethernet core.
did you see anything in the .QSF that might cause that problem?
Oren
