RBLUM7
6 years agoAccess AN639 Example Design files
I'm trying to download and look at the Design Examples from application note AN639 (Inferring Stratix DSP Blocks for FIR Filtering Applications). I can download the PAR files, but am not able to extr...
sstrell
6 years agoThe .par file should create a new project when you double-click it or you can install the .par file in the New Project Wizard as it instructs.
https://fpgacloud.intel.com/devstore/platform/16.1.0/Standard/stratixv_dsp_fir_verilog_basic_fir/
At what point are you having an issue with reading the files?
#iwork4intel
- RBLUM76 years ago
I tried again, using a different version of Quartus, 15.1 (I'm running linux, and our site maintains multiple versions), and it worked this time. I was able to unpack all. I'm not sure why that made a difference or if that was even the problem, but I'm good for now. Thanks anyhow, for the help.
