lambert_yu
Contributor
5 years agoAbout pll IP dynamic configuration of arria V can not success on board
Hi all,
I face one problem, when I simulate the pll dynamic configuration, the pll can lock after modifying setting(M,N,C) through reconfigure ip wethere I reset pll or not. But when I on board te...
lambert_yu
Contributor
5 years agoHi Eng Wei,
For the question you care:
1. external clock source is clean and pll can lock before reconfiguration;
2. I want to get 12Mhz output, but the output is close to the 24Mhz ( it's almost the same with the output frequency before reconfiguration).
3. Because of comfidentiality principle, I have no power to share the code, sorry.
Could you build one case, and see that you will get the same result?
Lambert
EngWei_O_Intel
5 years agoHi Lambert
there might be some issue with older version of Quartus:
Are you able to move to newer version of Quartus? Also, can you check if you have post scale counter being cascaded? Cascading post scale counter will not work for reconfiguration.
Eng Wei
