About lane stable of simplex transceiver RX
Do you observe Rx CDR loose lock intermittently in v18.0 Std ?
Assuming no changes in your design, one of the reason that I can think of is the IP upgrade is not done correctly causing IP design corruption.
- You can try delete the upgraded NativePHY IP then create a new fresh NativePHY IP in v18.0 std again
Another suggestion is pls try out newer latest Quartus version. v18.0 is too old
dlim
Hi Deshi,
After I add set_global_assignment -name PRESERVE_UNUSED_XCVR_CHANNEL ON,
I found that the transceiver work well for many compiled sof file except first compiled sof file ( for example, I make one new project folder).
I serch for the question about this assignment, I have the question as follow link :
About PRESERVE_UNUSED_XCVR_CHANNELfor transceiver application - Intel Community
Would you give me some advice, thanks.
Brs,
Lambert
