Gyud0
4 years agoA write memory problem via Quad SPI mode in Generic Serial Flash Interface IP
Hey,
I'm using the Reference design Generic Serial Flash Interface IP on Quartus Prime 18.1 to access Micron MT25QL512Mb flash memory.
Via NIOS processor, I'm trying to write data to this flash u...
EBERLAZARE_I_Intel
4 years agoHi,
Did you use this design?:
If not could you re-try using the above design, and let me know if the same issue occurs\.
