yt_liu
6 years agoA question about the clock signal of the CIC filter IP
Excuse me, I am testing the frequency response of the CIC filter IP using Quartus 19.1 Standard Edition and Arria V GX, and I have a question on the clock signal of the CIC filter IP core. I use the ...
SengKok_L_Intel
6 years agoHi,
It could be something related to the output rounding method, you may play around with that setting from the IP.
Regards -SK
yt_liu
6 years agoSorry for the late reply... I found out that I used a 1-bit PDM signal as the CIC filter's input but a signed signal should be at least 2 bits, and this caused the problem. Still thank you for your help! I think it may be better if the platform designer gives warning when the filter's input data width is set to 1 bit.
