FTang
6 years ago1pcs 10AX032H4F34E3SG failed in the field, we would like Intel help process further FA.
Based on SR information, the customer reported issue: "The input 2 HDMI connection dosen't work". Fault Duplication Test Plan: 1. Power up the unit 2. Extract available logs from unit 3. Verifyi...
NurAida_A_Intel
6 years agoHi,
This is Intel support agent.
Typical FA support process in Intel forum is via private message to protect customer design confidentiality.
I will initiate the private message discussion with you shortly.
Intel Support Agent
