1G/10G PHY single reference clock
- 6 years ago
Hi dlim,
I have found a solution working in the lab. For some reason generating the 125MHz from 644MHz with an IOPll seems to work, while using an fPLL has not.
I have attached a new clock diagram illustrating.
Joe
I've attached an illustration of my clocking. The notable difference is the lack of a 125MHz reference clock and my using the 644.53125 with cascaded fPLLs to generate 1GbE references.
I will look at the reference design and see if there are any other differences I should be concerned about.
Joe
Hi Joe,
Thanks for sharing your design clocking diagram.
Yup, the difference is mainly on 1G clocking side.
- Cascading fPLL is not recommended due to higher jitter affecting the clock network performance.
- Also, I am not sure how you connect 1G CDR (rx_cdr_refclk_1g) in your design. Based on reference design, this should be using same 125MHz clock source to clock both 1G Tx_PLL and 1G Rx_CDR
dlim
- jsenesi6 years ago
Hi dlim,
Joe
