ZWang142
6 years ago1/2.5/5/10G Multi-rate Ethernet PHY simulation cannot reach rx_block_lock
The simulation of the example design, provided by the "Low Latency Ethernet 10G MAC" IP, is running fine. However, when simulating my design, the PHY can not acheive rx_block_lock. The waveform sho...
Deshi_Intel
6 years agoHi,
I am able to duplicate the 322MHz example design sim run failure (rx_block_lock) stay low issue even in modelsim. While sim run with 644MHz setting is fine.
I am now consulting internally within Intel to figure out is this a bug or something that we miss out when using 322MHz setting.
Will keep you posted on status update
dlim
- ZWang1426 years ago
Hi @DeshiL_Intel ,
There is a core_pll in models/tb_top.sv that also needs to be changed, as it uses refclk_10g as well.
After modifying this pll, the example design is able to run with refclk_10g at 322 MHz.
Now I'm checking what's wrong with my design...
