1/2.5/5/10G Multi-rate Ethernet PHY simulation cannot reach rx_block_lock
HI,
Thanks for the clarification.
rx_pma_clkout is derived from rx_cdr_refclk_1. If you have provided correct clock frequency in test bench file then by right rx_pma_clkout should be 156.25MHz.
- I need to understand your design better and try to duplicate issue from my side.
Can you share with me more info as below ?
- Which FPGA product that you are using ? Is it Stratix 10 ? Can you share with me your FPGA part number ?
- Which Quartus version that you are using ? Have you tried with latest Quartus version like Quartus Pro v20.1 ?
- Which simulator tool and what version that you are using ? Make sure you are using the corresponding simulator tool that pair with its Quartus version
- Do you had a chance to try out other simulator tool to see of the issue still persist ?
- Lastly, can you share with me your Multirate-PHY IP setting screenshot ?
dlim
- ZWang1426 years ago
0. My rx_cdr_refclk_1 is 322.265 Mhz.
1- Stratix 10, 1SM16BEU2F55E2VG
2- Quartus Pro v20.1
3- VCS 2017
4- I tried Modelsim 10.6 on Windows but it failed to handle long file names. The testbench files provided by the example design have very long file names.
5- Please see the attached
In the example design, I changed the refclk to 322 MHz:
- Changed IP settings for the PHY and generated HDL for both syn and sim
- Changed IP settings for the 10g PLL and genreated HDL
- Changed refclk_10g in tb_top to 322 MHz
- Generated simulation scripts using Quartus
- Changed other simulation scripts so VCS can compile
Now, in the example design, rx_pma_clkout becomes 78 MHz and it cannot achive rx_block_lock.
Would you please try 322 MHz for the "alt_em10g32_0_EXAMPLE_DESIGN/LL10G_1G_2_5G_10G" example design?
