100G Ethernet MAC : Transceiver configuration
- HBhat27 years ago
Contributor
Hi @DeshiL_Intel ,
Is there any special skew calculation/estimation method for adjacent channels in a bank other than 3.9.4. Skew Calculations. In my view, the skew must be minimum between adjacent channels and increases with channel neighborhood. Correct me if my understanding is wrong.
With regards,
HPB
- Deshi_Intel7 years ago
Hi HPB,
Sorry, we don't have other calculation method.
dlim
- HBhat27 years ago
Contributor
I am trying to implement Soft Bonding feature to support my requirement with 20.625Gbps. I understand that I need to set TX Core FIFO mode to Interlaken to get the fifo control ports as mentioned in the Soft bonding flow in the Transceiver userguide.
I am facing some problem while I configure L-tile native PHY in Interlaken mode. So, is it possible to share the native phy configuration required to use 100G Ethernet IP, so that I can use the same setting in my implementation?
With regards,
HPB
