alexforencich
4 years ago100G E-Tile system console connection problem
I am running in to an issue with debugging the E-Tile in 100G mode via the system console. Even though I have the "Enable JTAG to Avalon Master Bridge" option selected in the parameter editor, I am ...
paveetirrasrie_Altera
4 years agoHi Alex,
Good day.
Kindly try to check your MAC configuration through example design in AN647. I have attached the link for your reference. Try to compare the MAC configuration with your design.
Kindly download the example design and unarchive, there is a file called "config.tcl", this file contains the MAC register setting. System console will source this file to configure the MAC register.
And also kindly try to confirm whether this issue exist in design example. Design example will help to find the missing piece.
Pavee
