LCard2
7 years ago.qip and .sip generated files manually added to project . On compile entities in .qip not found. Before I start cutting and pasting modules into existing.v files, what's proper way to incorporate these PLLs? Details of transcript warnings below.
Warning (20013): Ignored 16 assignments for entity "IPpll" -- entity does not exist in design Warning (20014): Assignment for entity set_global_assignment -name IP_TOOL_NAME altera_pll -entity IPpl...
LCard2
7 years agoHi Vicky,
1.) Quartus Prime Version 18.1.0 build 625 09/12/2018 SJ Standard Edition
2.) Used IP Install Catalog (which has subsequently become inoperative) to generate a reference clock and 5 PLL output clocks. Files attached.
3.) ModelSim Free version 105.b
I have seen that there is no Generate Simuator Setup Script in the Quartus standard – I used the command line “ip-make-simscript” to generate mentor/modelsim_setup.tcl.
I set parameters in Msimsetup.do . Attached – note underscore deleted. It is in C:/Steamboat/_Active Probe Card/FPGA/mentor
Now I think it’s a matter of setting the correct paths.
I have copied all necessary .v files into C:/Steamboat/_Active Probe Card/FPGA. I am not launching the simulator from the IP script location.. what do you suggest? How would I set a path? Or should I move everything into location where simulator is launched?
Thank you.
Len
