DLiu5
7 years ago!!!Stratix 10 runs OPENCL BSP: Can't run the Timing Analyzer.Error (23031):Evaluation of Tcl script compile_script.tcl unsuccessful
Our customer's PC have 96GB DRAM, when he compiles a BSP(DE10_Pro_OpenCL_BSP_18.1.1.tar.gz, provided byTerasic), it reports: (please see the log information at the end of this text). He did try to se...
MuhammadAr_U_Intel
Contributor
7 years agoHi,
Looking at the current log file you shared i can see there is an Internal Error at the end which means Fitter crashed.
Can you ask your customer to try compilation with S10 BSP provided by Intel as part of installer package.
What OS your customer is targeting ?
Did they used the OpenCL example from installation directory ?
Also can you check what is the peak memory utilized by fitter during compilation process, you should be able to check with "top" command in linux or in quartus_sh.log file.
Arslan
DLiu5
7 years agoThe OS is CentOS Linux release 7.4.1708, and the software is Quartus II 18.1.1, and he did installed the patch indicated in https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2019/internal-error--sub-system--qhd--file---quartus-comp-qhd-qhddata.html.
The rest I will ask the customer and reply you soon.
