!!!Stratix 10 runs OPENCL BSP: Can't run the Timing Analyzer.Error (23031):Evaluation of Tcl script compile_script.tcl unsuccessful
- DLiu57 years ago
The OS is CentOS Linux release 7.4.1708, and the software is Quartus II 18.1.1, and he did installed the patch indicated in https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2019/internal-error--sub-system--qhd--file---quartus-comp-qhd-qhddata.html.
The rest I will ask the customer and reply you soon.
- DLiu57 years ago
The message from the customer:
The stock s10_ref w/ would s10gx has no compile errors:
aoc device/vector_add.cl -o bin/vector_add.aocx -board=s10gx
However, it only generates these files in bin/ :
l
total 108
-rwxr-xr-x 1 root root 55584 May 6 17:15 host
drwxr-xr-x 9 root root 4096 May 6 17:20 vector_add
-rw-r--r-- 1 root root 15200 May 6 16:37 vector_add.aoco
-rw-r--r-- 1 root root 12372 May 6 16:37 vector_add.aocr
-rw-r--r-- 1 root root 12372 May 6 16:37 vector_add.aocx.tmp
Why is there no vector_add.aocx ??
quartus_sh_compile.log attached
swap makes no sense anyhow, the fitter uses 25% of the memory for a
total of 24GB (incl. all processes) w/ nearly 18GB free. Swap remains
unused (0% used).
- DLiu57 years ago
posted a file.
- DLiu57 years ago
I asked the customer to use this command instead: aoc -bsp-flow=flat vector_add.cl -o bin/vector_add.aocx -baord=s10_gh2e2 -v, and it works,
"Could you check w/ your engineer
1) which aoc flags and
2) which Linux distribution+version he was using?(We terasic use Centos 7.3.1611 Quartus 18.1.1.263 )
That will also help me.
It still looks like a bug, but if there's a work-around, then OK.
The problem I might get is when "flat" mode does not work, I will need
the non-flat mode, which seems broken.
And I need this under Linux due to HPC and ML kernel execution under
OpenCL. Windows is not an option.
