15 years ago
XAUI Phy in Stratix IV GX
actually I'm using the Stratix IV GX Devkit (EP4SGX230KF40) and try to implement a communication using the HSMC- loobpack adapter on port HSMCA. The protocol I'm using is XAUI. I started with the ALTGX and ALTGX_RECONFIG Megafunctions and a pattern generator in conjunction with a pattern checker. This little testdesign works fine in some cases. Mostly the lanes on the receiver are mixed up compared to the transmitter even though the rx_channelaligned signal is set to '1' from the ALTGX function.
There is an example desing on Alterawiki (http://www.alterawiki.com/wiki/xaui_design_example_1 (http://www.alterawiki.com/wiki/xaui_design_example_1) for Stratix V. This example use the XAUI_PHY and ALT_XCVR_RECONFIG megafunctions. I want to check if these functions solve my problem. Does any body know if the ALT_XCVR_RECONFIG are available for Stratix IV?
Are there some ideas about the lane mix up?
Jens
    Hi Dave,
    the lanes are scrambled. If I send at tx_datain X"FFEEDDCCBBAA9988" the I receive at rx_dataout X"EEFFCCDDAABB8899". (see attached signal tap screenshots tx_datain.jpg and rx_dataout.jpg)
    In some cases the alignment is correct (rx_dataout2.jpg). Before sending the data I use two start packets. The transmission of these packets is always incorrect (see the screenshots).
    Which megafunction you are using? ALTGX and ALTGX_RECONFIG?
    What are your parameter settings? (if you want have a look at my settings, see params at the end of reply)
    Which clocks you re using? I use for XAUI Refclk the LVDS clock source at pin AA2 (156.25 MHz)
    For the dynamic reconfiguration circuit I'm using the freerunning clock clkin_50 at pin AC34.
    The data generator is clocked with the coreclockout from ALTGX block.
    How is your implementation of the reset controller for ALTGX_RECONFIG?
    My reset sequence is like in the Stratix IV Device Handbook Volume 2: Transceivers, page 4-8, figure 4-4. (see attached altgx_reset1.jpg and altgx_reset2.jpg)
    There just is one difference. In my case the busy signal is always '0'.
    How do you verfy the transmission? With external or internal loopback?
    p.s.
    I try using the XAUI_PHY (external reconfig is not required) like in the example for Stratix V.
    I didn't succeed. (tx_ready and rx_ready signals are always '0')
    Jens
    ALTGX settings
    General
    protocol: xaui
    nr of channels: 4
    channel width: 16
    effective data rate: 3125
    clock freq.: 156.25
    base data rate: 3125.0
    PLL/ports
    train transceiver clock : enabled
    optional ports: enabled
    ports/calibration
    analog power: auto
    Rx analog
    static equalizer ctrl: disabled
    DC gain: 0
    common mode voltage: 0.82
    termination resistance: 100 ohm
    Tx analog
    transmitter buffer power: auto
    transmitter common mode voltage: 0.65
    transmitter termination: 100 ohm
    next parameter all to 0
    Reconfig sttings
    just offset cancellation is enabled
    --- Quote Start ---
    --- Quote End ---
    I have this kit.
    --- Quote Start ---
    --- Quote End ---
    I have not seen any lane assignment errors on this board. Do you mean that the data is scrambled from what you expect?
    Cheers,
    Dave
