17 years agoWrite to Flash utility
Hi, I am trying to program a design into the Flash memory of a Stratix II DSP Dev Board, and I am running into problems. A while back, I used a "write to flash utility" to program the Fl...
17 years agoIt looks like the solution was to use the standard example design.
The steps were: 1) recompile example_designs/vhdl/standard/ project using ES version 2) load FPGA 3) run: nios2-flash-programmer --base=0x0 --device=1 --instance=0 --accept-bad-sysid --cable=USB-Blaster --program <filename>.flash I'm not sure what was the issue with the other provided code, but this solved the problem.
