17 years agoWrite to Flash utility
Hi, I am trying to program a design into the Flash memory of a Stratix II DSP Dev Board, and I am running into problems. A while back, I used a "write to flash utility" to program the Fl...
17 years agohi aekosky,
Are you sure time-limited nios will start from flash? it needs cable for run. It's probably time-limited nios just doesn't support flash programming.
