17 years agoWrite to Flash utility
Hi, I am trying to program a design into the Flash memory of a Stratix II DSP Dev Board, and I am running into problems. A while back, I used a "write to flash utility" to program the Fl...
17 years agohi ninjaben,
you could upload to FPGA NIOSII project with flash controller and write flash by nios2-flash-programmer # # programmin USER0 FPGA configuration # SW2[0..2] = close, SW2[3] = open, SW2[4..8] = n/d. # # convert .sof to .flash file sof2flash --input=my_sof.sof --output=my_sof.flash --offset=0x00900000 # write flash nios2-flash-programmer --base=0x01000000 --program my_sof.flash startix ii ep2s60 kit offset is a 0x00500000 (not sure, check docs) startix ii ep2s180 pro kit offset is a 0x00900000 -- base means base address of the flash controller in the sopc-system.
