KLohr's avatar
KLohr
7 years ago
Working on encryption with max 10 device. Having problems programming .ekp & .pof separately
I programmed the .ekp with no problem, but every time I try to program the .pof, it fails. Also, don't understand from the ug_m10_config.pdf section 3.8.3.1 #9."Check only the functional block that need to be updated at child level for CFM and UFM. Do not check operation at the parent level when using Programmer GUI." What does this mean? I think I've tried every combination of boxes checked in the programmer mene
  • KLohr's avatar
    KLohr
    Quartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
    FPGA DEVICE 10M16SAU169I7G
    Additionally, since I didn't want to lock up my PCB with the 10M16 on it, I decided to go back to the Altera 10M08 Eval board and do some testing with that. I'm having a problem using the DEVICE 10M08SAE144C8GES on that board programming the part as described in section 3.8.3.2 ug_m10_config.pdf Integrate the .ekp into .pof Programming. I converted the file using the key in the example. I programmed the key and the file both together and now the device doesn't work and I can't program it any longer. I'm happy to send you any files that might help understand my issues.
  • Vicky1's avatar
    Vicky1
    May I know the following details?
    1. Quartus tool Edition(Lite/Std/Pro) & version used
    2. Device used(FPGA)
    Vicky
