KLohr
7 years agoWorking on encryption with max 10 device. Having problems programming .ekp & .pof separately
I programmed the .ekp with no problem, but every time I try to program the .pof, it fails. Also, don't understand from the ug_m10_config.pdf section 3.8.3.1 #9."Check only the functional block that ...
KLohr
7 years agoQuartus Prime Version 18.1.0 Build 625 09/12/2018 SJ Lite Edition
FPGA DEVICE 10M16SAU169I7G
Additionally, since I didn't want to lock up my PCB with the 10M16 on it, I decided to go back to the Altera 10M08 Eval board and do some testing with that. I'm having a problem using the DEVICE 10M08SAE144C8GES on that board programming the part as described in section 3.8.3.2 ug_m10_config.pdf Integrate the .ekp into .pof Programming. I converted the file using the key in the example. I programmed the key and the file both together and now the device doesn't work and I can't program it any longer. I'm happy to send you any files that might help understand my issues.
