14 years agoWiring Optimization
Hi, I’m now developing my custom board based on Cyclone III FPGA (EP3C120). In my design, I have several fast input lines (3) with 10MHz base clock, 100MHz after PLL, max stages for pipeline. ...
14 years agoAnd yes forgot to answer your last qustion.
You can refer to the fit report for the pin assignments. The heading will be as "Input pins" & "Output pins" and it will give you the exact pin location where the quartus placed. After knowing that you can give location assignments through .qsf giving the pin locations.
