15 years agowire the 16207 lcd to nios2 module
I have a EP3SL150 board and want to use the 16207 lcd on it with my nios2 processor! I already included the corresponding module in my sopc design and generated my processor. Now i have to wire...
15 years agoi have now wired the pins as you sayed but it is still not working :(
i now think that the main problem are the data pins which should be inout. Maybe i did indeed something wrong in my toplevel file. i don't know what it is because for me it looks quite ok! :) here is my toplevel file:library IEEE;
use IEEE.std_logic_1164.all;
use work.noctypes.all;
entity canrouter is
port
-- global signals
clkin_50 : in std_logic; -- clock input, 50 MHz
user_resetn : in std_logic; -- user reset
-- the lcd display
LCD_E_from_lcd_6 : out std_logic;
LCD_RS_from_lcd_6 : out std_logic;
LCD_RW_from_lcd_6 : out std_logic;
LCD_data_to_and_from_lcd_6 : inout std_logic_vector(7 DOWNTO 0);
-- the_uart_0
rxd_to_uart_0 : in std_logic; -- uart rxd
txd_from_uart_0 : out std_logic; -- uart txd
-- the_uart_1
rxd_to_uart_1 : in std_logic; -- uart rxd
txd_from_uart_1 : out std_logic; -- uart txd
-- the_uart_2
rxd_to_uart_2 : in std_logic; -- uart rxd
txd_from_uart_2 : out std_logic; -- uart txd
-- the_uart_3
rxd_to_uart_3 : in std_logic; -- uart rxd
txd_from_uart_3 : out std_logic; -- uart txd
-- the_uart_4
rxd_to_uart_4 : in std_logic; -- uart rxd
txd_from_uart_4 : out std_logic -- uart txd
end canrouter;
architecture structural of canrouter is
signal wsysclk : std_logic;
signal wmtclk : std_logic;
signal wUNI_in : vt_uni_in(6 downto 0);
signal wUNI_out : vt_uni_out(6 downto 0);
begin
-- macro tick generation
mtgen_inst : entity work.mtgen(behavioural)
generic map
CNT_VALUE => 953,
ITER_VALUE => 4
port map
clk => wsysclk,
mtclk => wmtclk,
reset_n => user_resetn
-- component instance of network-on-chip
noc_inst : entity work.noc(structural)
-- noc_inst : component noc
generic map
NROFTISS => 7,
ROWS => 1,
COLS => 3,
INTERCONNECTS => 4,
MEMINIT_DIR => "../meminit/"
port map
UNI_in => wUNI_in,
UNI_out => wUNI_out,
FS_Enable => (others=>'1'),
clk => wsysclk,
mtclk => wmtclk,
-- component instance of SOPC Component
sopc_inst : entity work.userland(europa)
-- sopc_inst : component work.userland
port map
-- the_avalon_tiss_0
CIAddr_from_the_avalon_tiss_0 => wUNI_in(0).CIAddr,
CINameSpace_from_the_avalon_tiss_0 => wUNI_in(0).CINameSpace,
CIRDData_to_the_avalon_tiss_0 => wUNI_out(0).CIRDData,
CIRDEna_from_the_avalon_tiss_0 => wUNI_in(0).CIRDEna,
CIWRData_from_the_avalon_tiss_0 => wUNI_in(0).CIWRData,
CIWREna_from_the_avalon_tiss_0 => wUNI_in(0).CIWREna,
PIAddr_to_the_avalon_tiss_0 => wUNI_out(0).PIAddr,
PIMemErr_from_the_avalon_tiss_0 => wUNI_in(0).PIMemErr,
PIRDData_from_the_avalon_tiss_0 => wUNI_in(0).PIRDData,
PIRDEna_to_the_avalon_tiss_0 => wUNI_out(0).PIRDEna,
PIWRData_to_the_avalon_tiss_0 => wUNI_out(0).PIWRData,
PIWREna_to_the_avalon_tiss_0 => wUNI_out(0).PIWREna,
SBMasterInt_to_the_avalon_tiss_0 => wUNI_out(0).SBMasterInt,
-- the_avalon_tiss_1
CIAddr_from_the_avalon_tiss_1 => wUNI_in(1).CIAddr,
CINameSpace_from_the_avalon_tiss_1 => wUNI_in(1).CINameSpace,
CIRDData_to_the_avalon_tiss_1 => wUNI_out(1).CIRDData,
CIRDEna_from_the_avalon_tiss_1 => wUNI_in(1).CIRDEna,
CIWRData_from_the_avalon_tiss_1 => wUNI_in(1).CIWRData,
CIWREna_from_the_avalon_tiss_1 => wUNI_in(1).CIWREna,
PIAddr_to_the_avalon_tiss_1 => wUNI_out(1).PIAddr,
PIMemErr_from_the_avalon_tiss_1 => wUNI_in(1).PIMemErr,
PIRDData_from_the_avalon_tiss_1 => wUNI_in(1).PIRDData,
PIRDEna_to_the_avalon_tiss_1 => wUNI_out(1).PIRDEna,
PIWRData_to_the_avalon_tiss_1 => wUNI_out(1).PIWRData,
PIWREna_to_the_avalon_tiss_1 => wUNI_out(1).PIWREna,
SBMasterInt_to_the_avalon_tiss_1 => wUNI_out(1).SBMasterInt,
and so on............
-- the_avalon_tiss_6
CIAddr_from_the_avalon_tiss_6 => wUNI_in(6).CIAddr,
CINameSpace_from_the_avalon_tiss_6 => wUNI_in(6).CINameSpace,
CIRDData_to_the_avalon_tiss_6 => wUNI_out(6).CIRDData,
CIRDEna_from_the_avalon_tiss_6 => wUNI_in(6).CIRDEna,
CIWRData_from_the_avalon_tiss_6 => wUNI_in(6).CIWRData,
CIWREna_from_the_avalon_tiss_6 => wUNI_in(6).CIWREna,
PIAddr_to_the_avalon_tiss_6 => wUNI_out(6).PIAddr,
PIMemErr_from_the_avalon_tiss_6 => wUNI_in(6).PIMemErr,
PIRDData_from_the_avalon_tiss_6 => wUNI_in(6).PIRDData,
PIRDEna_to_the_avalon_tiss_6 => wUNI_out(6).PIRDEna,
PIWRData_to_the_avalon_tiss_6 => wUNI_out(6).PIWRData,
PIWREna_to_the_avalon_tiss_6 => wUNI_out(6).PIWREna,
SBMasterInt_to_the_avalon_tiss_6 => wUNI_out(6).SBMasterInt,
-- 1) global signals:
clk_50 => clkin_50,
sysclk => wsysclk,
reset_n => user_resetn,
-- the_lcd_display_6
LCD_E_from_the_lcd_6 => LCD_E_from_lcd_6,
LCD_RS_from_the_lcd_6 => LCD_RS_from_lcd_6,
LCD_RW_from_the_lcd_6 => LCD_RW_from_lcd_6,
LCD_data_to_and_from_the_lcd_6(7 downto 0) => LCD_data_to_and_from_lcd_6(7 downto 0),
-- the_uart_0
rxd_to_the_uart_0 => rxd_to_uart_0,
txd_from_the_uart_0 => txd_from_uart_0,
-- the_uart_1
rxd_to_the_uart_1 => rxd_to_uart_1,
txd_from_the_uart_1 => txd_from_uart_1,
-- the_uart_2
rxd_to_the_uart_2 => rxd_to_uart_2,
txd_from_the_uart_2 => txd_from_uart_2,
-- the_uart_3
rxd_to_the_uart_3 => rxd_to_uart_3,
txd_from_the_uart_3 => txd_from_uart_3,
-- the_uart_4
rxd_to_the_uart_4 => rxd_to_uart_4,
txd_from_the_uart_4 => txd_from_uart_4
end structural;
