15 years agoWindows freezing with hard IP PCIe driver
I have a small driver enumerating the BARs. It is general in nature and works perfectly on several other PCI boards. When using it with a board containing the Cyclone IV GX, (Altera demo board for...
15 years agoI now tried with a Jungo-generated minimal driver, with the same result. It looks like the problem is coming from the way that I generated the PCIe interface?
I can access correctly the registers on my board, or on the Altera evaluation board, however they both die when I try to disable the driver or shut down the system.
