Windows 10 driver support for USB Blaster ?
In reviewing the drivers download page it appears there are NO drivers for Windows 10 for the USB based Blaster programmer cables.
Is this really true ?36 Replies
- Sudhamshu_B_N
Finally found solution, For de10 lite https://github.com/sudhamshu091/USB-Blaster-Driver-for-DE10-lite and de10 nano and de1 soc https://github.com/sudhamshu091/USB-Blaster-ii-Driver-for-DE10-Nano
- jensk
Can anyone tell how to get USB Blaster drivers working with Terasic DE10-Nano on Windows 10? This board has a USB product ID of 6810, which seem to be listed in the .INF file of the newer, unsigned drivers. The old, signed drivers can install, but does not list product ID 6810 in the .INF file, so Windows will not use it for the DE10-Nano.
I'm at a loss, and I cannot believe this is Intel's standard.- jensk
Finally got it working - in new Windows 10 versions you have to reboot into troubleshooting mode to disable check of driver signing. This way I could install the drivers from Quartus Prime Light 21.1 drivers, which recognize the DE10-Nano. Like so:
https://support.viewsonic.com/en/support/solutions/articles/33000252416-how-to-install-unsigned-drivers-in-windows-10
Wonder if we will ever get this working with Windows 11?
- sickle
Unsigned drivers in 2021, from Intel? Poor form.
I managed to get them installed on 20H2 (19042) 64 bit by:
- downloading TScho16's linked drivers
- windows complains that a file is missing
- so copy in the files from the quartus 20.1\drivers\usb blaster\ folder
- *skip* conflicts
- point windows at the merged folder
Your mileage may vary. - twboy
Check this link for a detailed solution:
http://www.airsupplylab.com/fpga/275-fpga-kb-01-install-intel-quartus-prime-and-driver.html
- zhang297
In case anybody else is still struggling with this, the page below has a link to the update driver.
The driver in the latest 20.1.1 download is sadly still broken. I just tried today...
Anand-
Ok, I think I've finally got it. The Jtag cable can be used for configuration. Everything is running. -J - Altera_Forum
Hi Anand-
The confusion is on my part. I thought it was possible to download to the DE10-standard (terasic) via the USB connector... of course this explains why windows shows it as a usb com port... because it is. I may end up purchasing the USB-Blaster cable. I'll have to see how far I can get w/o it setting up configurations via the HPS. Thanks so much for your prompt replies. It is nice to know I will not be left hanging even for minor issues like this one. -J - Altera_Forum
Have you connected the Blaster to right header/port(jtag) on your board? Which Dev Kit are you using? Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) - Altera_Forum
--- Quote Start --- Hi, Right click on "unknown device"->UPdate Driver Software->Browser to the Quartus installation directory ("C:\intelFPGA\17.0\quartus\drivers\usb-blaster")->click next. If it does not solve the problem try previous post by garypace. Or Reinstall the Quartus tool. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Hi Anand- Thanks for replying. The connection does not show up as "unkown device". Instead it shows up as a fully configured "USB Serial Port (COM4)". Could this be a part of the problem? Windows does not change the driver after: UPdate Driver Software->Browser to the Quartus installation directory ("C:\intelFPGA\17.0\quartus\drivers\usb-blaster")->click next. Thanks, -J - Altera_Forum
