BWalker
2 years agoWill a Cyclone IV be damaged if a a 3.3V LVTTL output is driven high, but connected to ground?
Will a Cyclone IV be damaged if a 3.3V LVTTL output is driven high, but connected to ground? The pin has the current strength set to 8 mA. I'm working on an old design where the original designer a...
- 2 years ago
Thank you for answering my question!
However, I'm still misunderstanding something.
I thought it would be safe, because this pin has the "CURRENT_STRENGTH_NEW 8MA" assignment set. I thought this meant there was an internal current limiting feature to limit the output current to 8 mA under any situation, including when shorted to ground.
8 mA is well below the Absolute Maximum Rating of 40 mA for the DC output current per pin.
Would you please confirm I misinterpreted how this works?
Thank you!
FvM
2 years agoHi,
according to output characteristics documented in Ibis files, shorted output current ttl33 8mA will probably exceed absolute maximum ratings for pin current. Damage possible.
