BQi
6 years agowhy we can not generate pcie ep ipcore example design?
we use below ip config, but we can not generate pcie ep ipcore example design, pls help
BoonT_Intel
6 years agoHi Sir,
After playing around the setting on by one, I found the culprit is "Address width of accessible PCIe memory space".
The generation errors will occur when we set the value to 63 and 64. It will generate the example design successfully when we set the value to 62 and below.
As temporary work around, can you generate the design using "Address width of accessible PCIe memory space" set to 62 or below?
- BQi6 years ago
Which tab has The parameter “Address width of accessible PCIe memory space”?
