17 years agowhy the simulation result is differenct between fork join and begin end?
this is the testbench in an495. why can not use begin ... end. initial begin arst <= 1'b0; // resetting the contoller initially # 250 arst <= 1'b1; ider...
17 years agoThe begin-end-block also assigns the values to the nets simultaneously if non-blocking assignments are used (as it's the case in the example). The difference is that all timing assignments are with respect to the block entry time in case of fork-join and with respect to the previous timing assignment in case of begin-end.
