17 years agowhy the simulation result is differenct between fork join and begin end?
this is the testbench in an495. why can not use begin ... end. initial begin arst <= 1'b0; // resetting the contoller initially # 250 arst <= 1'b1; ider...
17 years agoThe difference between "begin-end" and "fork-join" is that in initial block "begin-end" operations work step-by-step, but in "fork-join" they work simultaneously. You can rewrite the testbench using "begin-end". For example,
begin arst <= 1'b0; // resetting the contoller initially iderst <= 1'b0; ideen <= 1'b1; pioiordyen <= 1'b1; piorqst <= 1'b1; pioaddr <= 4'b0111; piodatain <= 16'b1111111100000000; piowe <= 1'b1; iordy <= 1'b1; intrq <= 1'b1; flag <= 1'b0; //if error occured in the test procedure,then asserted ddi <= 16'b0000000011111111; # 250 arst <= 1'b1; # 350 piowe <= 1'b0; # 4400 $stop; end I believe, it will work like original "fork-join"
