Why my Intel Cyclone10 GX can't connect to 10Gbps network adapter on PC ?
Hi Sgeor22,
Thank you for posting in our Intel® Ethernet Communities Page.
We are sorry to hear about the issue that you are experiencing with your setup.
Your thread was assigned to us so we can check the network adapter side of things. Although, it works when connecting two network adapters together, we need to check if something from the adapter is causing it to no establish a link with your Cyclone FPGA.
We would like to get some configuration logs for your system with the Intel® network adapter. May we know what Operating System are you using for the Intel(R) Ethernet Server Adapter X520?
We look forward to hearing from you. If we do not get your reply, we will follow up after 3 business days.
Alfred S
Intel® Customer Support
- SGeor225 years ago
Of course. Where these logs can be found on the system?
Windows 10 x64
