why must I need to generate two jesd204b ip core when I use two ADC?
- 3 years ago
Hi Allen,
Apologize for the delayed response.
Regarding to your question, If both share the same IP, there is no mechanism to check and ensure that the data are aligned. The data transmitted by the two ADCs will not be synchronized, high likely will arrive at different times. With multiple JESD IP, even if data can arrives at different time, there is a mechanism to ensure the RX IP data can align and then achieve synchronization behaviour.
The below concept is for JESD204C, which is applicable to JESD204B too.
Screenshot
Hope this answers your question.
ZulsyafiqH_Intel
Hi Allen,
Thank you for your respond.
I’m glad that your question has been addressed, with that, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
ZulsyafiqH_Intel
