yxm00
6 years agoWhy MAX10 always boot from CFM0 when power up?
There are 2 different image in Max10(10M08SAE). Pin of CONFIG_SEL , 10-KΩ pull-down. I have set config_sel_overwrite=1, config_sel= 1( When I trigger FPGA to reconfigure by DualBoot IP, it can ...
- 6 years ago
If you are using the Dual Boot IP, then you will need to write a state machine to on your image0 so that after setting the config_sel_overwrite and config_sel then you only you trigger the reconfigure through the IP.
If you would like to boot to Image1 after power cycle then you will need to connect CONFIG_SEL pin to 10-KΩ pull-up.
JohnT_Altera
6 years agoYour welcome. Please feel free to create new forum case if you have any other queries.
