RDM
7 years agoWhy Gated clock design has better FMAX?
I've been reading "RTL Hardware Design Using VHDL: Coding for Efficiency, Portability, and Scalability" by Pong P. Chu. I'm in section 9.1.2 ("Misuse of gated clocks"), which explains that we should ...
RDM
7 years agoHi,
I changed the SDC and had the same strange results. The "gated_clk_arch" architecture has a FMAX much bigger than "two_seg_arch" architecture.
I always get the same results whether I use the same Quartus Version and same vhd, even on Linux or Windows. Doesn't matter how many times I compile the design. I get different placement and routing just when I change the constraints (*.SDC), the code (*.VHD) or some Quartus configuration (Optimization Technique, Logic Lock, etc.) .
