16 years agoWhy does the Parallel Flash Loader (PFL) fail to configure my FPGA after programing f
use PFL (in MAX II device) configure FPGA.Based on an386.pof,I found Quartus programmer can erase and program flash using pfl. However,after programing flash, pfl fails to configure FPGA. The config...
16 years agoThe size of CFI specified in PFL must be same as the actual flash size or bigger. Change the settings and try again to see if the problem still occurs. The rule: actual flash must be less than or equal to size specified in PFL
