8 years agoWhy does Quartus schematic editor cut off text?
The schematic editor seems to always clip the last characters of the pin names and node names (and other text). Is this expected behavior? Has anybody else noticed it and is there a fix or a setting ...
8 years agoI get exactly the problem as originally described when using a 1920x1080 primary monitor (set to 150%) and a 1920 x 1200 secondary (28", the one I am trying to work on, set to 100%). The problem occurs with labels, free text and even the text within Altera primitives. The only thing which seems to fix it is to set the primary monitor back to 100% - and then reboot the PC. Then all seems to be well.
It would be good if this could be fixed properly (the primary monitor is 10.8", so at 100% the text is a challenge) but at least I can find my way round my schematics now. Hope that helps
