8 years agoWhy does Quartus schematic editor cut off text?
The schematic editor seems to always clip the last characters of the pin names and node names (and other text). Is this expected behavior? Has anybody else noticed it and is there a fix or a setting ...
8 years agoHi,
1. First insert any symbol then generate pins for symbol ports. 2. Then Change Fonts & style for the All types of text (Block, Instances, port names etc.) 3. Then again insert same symbol for two times then generate pins for symbol ports for the both. 4. Still if you not observed font change then there might be resolution issue, refer following thread. https://alteraforum.com/forum/showthread.php?t=53267 5. I am able to change color, font, style for internal/External of symbol refer screenshot. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar Intel Customer Support – Engineering (Under Contract to Intel)
