Why do I get the following relsult in my FIR filter output
- 3 years agoYou are using logical right shift for signed variables which corrupts the sign bit. Try arithmetic shift.
Please refer to below explanation.
For LINT-28 (warning) In design.
DESCRIPTION
This warning alerts you that a port in a design is not connected to any nets. This usually indicates
that a design has not been correctly specified. However, there are some situations where, as a
designer, you choose to specify a port on a design for compatibility reasons, even though the port
is not internal to design use. The Synopsys tools leave unconnected ports alone, with one
exception; that is, you specified that a given input port is opposite or equal to another input port in
a design.
WHAT NEXT
Make sure that you want the named port to exist in the given design, even though it has no
nets connected. Remove the port from your design if you choose.
For LINT-33 (warning) In design.
DESCRIPTION
check design issues this warning when it finds an instance of a hierarchical design (for
example, a sub-module) that has more than one input connected to the same net. This
warning is issued to verify that these are desired connections on the submodule. Be aware that
compile can remove logic in a design that is redundant. So, compile can produce designs that
display this warning if it determines that multiple inputs on a submodule are driven by the same
logical signal.
WHAT NEXT
Verify that you want the given submodule inputs connected to the same logical signal. If you have
run compile, you might want to use verify to verify the optimized design with your original. Or, use
the -verify option to compile whenever feasible.
Thank you
Kshitij Goel
